Old 07-10-2014, 12:35 AM   #561
Any headway on my lights, Pwave?
99 Porsche Boxster 986 3.8
85 Toyota Corolla AE86 F20C
12 Honda Accord
16 Mercedes C450 AMG
22 Tesla Model X Plaid
Old 07-10-2014, 09:08 AM   #562
BruceH's Avatar
I'm not 100% sure where this is going yet.
I am sure where ever it goes! it will be top shelf looking forward to the results!
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 07-10-2014, 11:14 AM   #563
Will there not be a lens ?
Yes, there will be a lens when it's done, haha!
particlewave is online now   Reply With Quote
Old 07-10-2014, 11:16 AM   #564
Thanks Bruce!
Not everyone's cup o' tea, I'm sure, but I think I'm going to like it
Pictures have been photoshopped to hide some things
Old 07-10-2014, 11:31 AM   #565
Just a dab of the green caliper paint on the HID cutoffs and around the Cree LEDs to carry the color in the lenses as seen in my last post.
Old 07-10-2014, 07:09 PM   #566
Nine8Six's Avatar
Funky! Quick question... those shotgun LED projectors, how do they hook up to the system? Are you planning to connect them to the parking light or the low beams? Fogs? Standalone circuit?
You need to put on the inner trim and the lens then fire it up so we can see what it will look like
(curious!)
Old 07-10-2014, 07:23 PM   #567
BruceH's Avatar
Thanks Bruce!
Who cares if someone else likes it or not! What you have so far is pretty cool looking. I am also curious about the outboard LED's.
DEPO Tail Lights
Old 07-10-2014, 07:31 PM   #568
Pdwight's Avatar
Me too
Remember the awful movie "Starship Troopers" ?
"Do you want to know more ?"
Yes we do :-)
Dwight
Old 07-10-2014, 08:16 PM   #569
(curious!)
I'm not sure yet.
They will either be DRL's or "flash to pass" daytime high beams. They are very bright. Blinding.
Combine that with the projector lens and they are actually very useful.
I mostly just like the way they look, though.
I'm resurrecting the old CCFL DRL idea, also. These will be nice because I made them so that the bulb can be changed through a plug in the side of the headlight (no need to remove the lens). They are also very bright.
Still a bit of work to go, but I'll have them finished in a week or so.
Old 07-10-2014, 08:22 PM   #570
Pdwight's Avatar
Cree
Could you do that with a frosted tube and a Cree at each end...should burn essentially forever.
Old 07-10-2014, 08:26 PM   #571
Nine8Six's Avatar
For that strip in the indicator, two words: "fiber optic". Look it up
Glad to see you are having fun there man. Lucky you (wish I had time to trick my toys here hrrr)
Old 07-10-2014, 08:50 PM   #572
Nine8Six's Avatar
In a week you'll have all of your customer's kit in hands (bity of a heads up). So yea everyone, expect this mod in Autumn lol
Was browsing at this CA guy's website ('80 style, beware btw)
http://www.fiberopticproducts.com/El_wire.htm
found this as well:
I've seen the Bill Me Later thing often but never really cared to look into it, what it meant. Until today. juss sharing man
(unbelievable)
Old 07-10-2014, 08:56 PM   #573
Pdwight's Avatar
EL Wire and electroluminescent wire
found this as well:
(unbelievable)
Why on earth are they still using inverters (Ballasts) with all the wonderful high output SMD these days ?
Old 07-10-2014, 08:59 PM   #574
Nine8Six's Avatar
Robust!!! lol
Old 07-10-2014, 10:57 PM   #575
I've actually tried those. The EL wire isn't nearly bright enough and led tube is spotty and a pain to repair if a single led goes out.
See above. The quest for tube lighting...led tubes aren't very bright and they still have that uneven spotty look.
Old 07-10-2014, 11:10 PM   #576
Pdwight's Avatar
This is not bright enough
50Watt Warm White LED IC High Power Floodlight Lamp Bulb Beads Chip DIY | eBay
Have you seen one of these ?
Old 07-11-2014, 07:23 AM   #577
this thread is AWESOME
mikeman is offline   Reply With Quote
Old 07-11-2014, 08:44 AM   #578
Gone
Davev's Avatar
I think it can now be called EPIC.
Davev is offline   Reply With Quote
Old 07-11-2014, 01:14 PM   #579
More headlight pron...
These could be ready by tomorrow, but I'm going to wait a day to see if anything else comes to mind before I re-seal them.
Old 07-11-2014, 03:38 PM   #580
Haha! That is probably crazy bright @ 50watts. Way too bright for my needs and I was referring to/looking for tube/strip lighting.
The Cree LEDs in the small projectors that I'm using are 1 watt each (330 mA @ 3 V) and are more than bright enough for DRLs, though I probably won't use them as such.
